跳转到主内容
加入维修社区 - 创建账户
1986 年至今的 Harley-Davidson Sportster 摩托车。
Strange sound from my engine
Hi guys, i bought a sportster 883 r two months ago and i knew from the mecanic that the guy i bought it from, had a failure in the oil pump and he drove 15 miles, the mecanic said he changed the pump and one from piston head. But a tic tic sound is coming from the engine and the sound becomes higher when i drive long distance, anyone can help me what this sound may be???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
I recently figured a new problem every 40 miles my rear spark plug is fouling is it related to the ticking sound??
完成的
Quite possible, is it oil fouling? If so your lifters may need adjusting, and if they are auto adjusting, you may need to replace either your chain/belt, slipper/tensioners. Does it blow a bit of smoke on start up, or when taking off from traffic lights. These are indications of valve stem seals and or valve adjustment.
完成的
Yes, it is blowing smoke on startup.
完成的
添加一条评论
1个答案
Tic ticking sounds are usually lifters. Or noisy valve train. I'd personally take it to another mechanic, don't tell him the story. See what that guys says it is.
这个答案有帮助吗?
得分 0
1条评论:
It could be anything really, as the engine may need a full rebuild.
完成的
添加一条评论
添加你的答案
Johnny Chebel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,262
