跳转到主内容
加入维修社区 - 创建账户
Samsung Xpress SL-C410W/XAA 彩色打印机维修信息。于 2013 年 7 月首次在亚马逊上架。型号:C410W。
Imaging Drum reset?
I have the xpress C410W laser printer. I have a model that does not have the resistor clipped into the front of drum unit. I have a plug in board located under cover on front door. I want to reset the drum as it’s in perfect condition, I purchased resistors but have no where to put them. This board that connects to the prongs that make contact with toner cartridges does this contain the resistor for the drum too? And what can I do to reset this drum?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
What size resistor did you use, my color code shows 1 Ohm. someone thought it was 56 Ohm. Thanks Dennis
由完成的
添加一条评论
3个答案
已选择的解决方案
My imaging unit did not have a resistor either so I twisted the resistor onto the two lowest contacts on the door (where the resister unit should touch if there) and powered the unit for a few minutes and the light went out. I then pulled off the restistor. I have the original imaging unit and mine is a C410W.
That worked for me.
PS. If at first it does not work then leave the resistor on and wait for all the printer to do its fits and stops and the light should go green. Then turn it off and pull off the resistor
这个答案有帮助吗?
得分 2
添加一条评论
Resistor is located behind two square contacts on the front side of imaging unit (below contacts for every toner).
Look at photos in this review article:
https://www.digitaltrends.com/printer-re...
image:
https://icdn9.digitaltrends.com/image/sa...
Hope it helps someone.
这个答案有帮助吗?
得分 0
添加一条评论
Everybody try to enlist yourself for the HSRP so you won't get fined. In the event that you are from outside Delhi yet live in Delhi, '''WB HSRP Book Online''' Visit your Vehicle enrollment State site for enlistment or contact your closest approved vendors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ginger 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 8,535
