跳转到主内容
加入维修社区 - 创建账户
适用于碎纸机、信用卡及其他各类文件的维修指南和支持。
How do I put shredder into alignment?
message on shredder says it is out of alignment. I tore it down to remove a paper jam put it back together and this message appeared. How do I get it BACK INTO ALIGNMENT?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
whats the model number?
完成的
添加一条评论
1个答案
Without knowing all the details, I can only suggest that you tear it down again. when you get to the blades, make sure the teeth are lined up alternately. I'm guessing when you pulled out the paper jam, it tweeked one/both of the blades. Make sure both blades are seated in the proper position.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michelle abruscato 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,227
