跳转到主内容
加入维修社区 - 创建账户
Logitech UE Boom 2 是一款防水、便携式蓝牙音箱,以其 360 度音效而闻名。Boom 2 提供多种鲜艳的配色和图案。
Sound quality is poor with PC
My Ue boom. works fine when connected to a phone, but when i connect it to my PC the audio coming out is absolutely terrible. Does anyone know a way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
16条评论
How are you connecting it? Bluetooth or cable?
由完成的 分享
It wasn't charging, so by bluetooth
由完成的 分享
Hi,
What is the make and model number of your PC?
What OS is installed?
由完成的 分享
My PC is a dell XPS 15 and is windows 10.1 64bit
由完成的 分享
I have the same issue with my Asus laptop (running Windows 10, 64bit)
由完成的 分享
显示更多的11条评论
添加一条评论
8个答案
最有帮助的答案
What solved this for me:
1. Connect the speaker and choose the MEGA BOOM Stereo device. Often you will get no sound when you do this at first.
2. Once selected turn the speaker off and back on again and when it auto reconnects it should connect the speaker device and work correctly.
If the above didn’t work try this as this worked for me for one of my machines.
1. Connect the speaker.
2. Go to Control Panel\All Control Panel Items\Devices and Printers and remove the “dongle”
3. Go to Control Panel\All Control Panel Items\Devices and Printers > right click on the MEGABOOM headphone icon and choose properties > Services > uncheck “Handsfree Telephony
4. Set your sound output to MEGA BOOM Stereo device, which will produce no sound.
5. Restart your MEGABOOM, once reconnected it will work correctly.
I have this issue on Windows 10 as well. There has to be something strange with the hardware being used in the mega boom. Windows picks up 3 separate devices when I connect to mine, a dongle which the driver will not work for, the hands-free headset, and the speaker. The handsfree headset is locked in at 16bit sound and sounds terrible. The setting is also locked out in sound manager you can’t change the bit rate for the headset device. I tried everything from getting drivers to work with the “dongle” that is seen to disabling things in the device manager, updating bluetooth drivers, etc.
这个答案有帮助吗?
得分 12
9条评论:
Thanks!! This helped
由完成的 分享
Thanks for the answer man. Spent hours looking for a solution! Had to create an account just to say thank YOU !!!!
由完成的 分享
simply changing the output also didn't work for me with my Boom 2, but your solution did! thank you!
由完成的 分享
Thank you! The uncheck "handsfree telephony" works for me
由完成的 分享
The on/off trick solved it for me as well. Thank you, Seth! I also made this account just to be able to say thx. Have a nice day
由完成的 分享
显示更多的4条评论
添加一条评论
I have the same problem with my UE Boom 2 when listening on my MacBook Pro. Just fixed it by changing the Sound Input to Internal Microphone instead of Boom and keep UE Boom on Sound Output only.
Hope it helps.
Cheers,
C
这个答案有帮助吗?
得分 4
4条评论:
This is the one!!! All macbook users this is the answer!!!!
由完成的 分享
This fixed it! Thanks!!!!
由完成的 分享
Holy cow this was driving me nuts!!! THIS IS THE ANSWER IF YOU HAVE A MACBOOK!! I was trying to work out how the Boom got assigned to audio input - I reckon it was Skype when I used it earlier today.
由完成的 分享
Yay!!!! Thank youuuuuu <3
由完成的 分享
添加一条评论
I would suggest trying this guide for fixing Bluetooth audio quality on windows: https://www.youtube.com/watch?v=55yn-zF_...
这个答案有帮助吗?
得分 3
8条评论:
Didn't fix it sound quality is still poor, and i cannot uncheck the handsfree telephony because the ue boom will disconnect
由完成的 分享
Then I would keep my eye out for a firmware update that may fix the issue.
由完成的 分享
You sir are a lifesaver - I was getting very frustrated with the sound quality of a ue megaboom but your suggestion fixed it. Thank you so much!!!!
由完成的 分享
peter eddleston, what was the suggestion that solved your problem, Pleeaaase!
由完成的 分享
I have the same problem as Emerson "
Didn't fix it sound quality is still poor, and i cannot uncheck the handsfree telephony because the ue boom will disconnect"
由完成的 分享
显示更多的3条评论
添加一条评论
Go to Control panel > Devices & Printers > Select your device > Properties > Services > Uncheck Handsfree telephony
Hope this helps
这个答案有帮助吗?
得分 3
1条评论:
I'm not getting any sound from the Stereo one but I getting bad quality sound from Handsfree... I don't know how to fix the problem to get sound trough Stereo? any ideas why?
由完成的 分享
添加一条评论
You need to make sure the sound output is set-up as "UE Boom 2 Stereo" NOT "UE boom 2 Hands Free"
这个答案有帮助吗?
得分 2
2条评论:
"UE Boom 2 Stereo" produces no sound at all. :( The other one bad quality.
由完成的 分享
Yay! It worked! Thanx heaps!
由完成的 分享
添加一条评论
Might be there is a problem in the port of your computer.
这个答案有帮助吗?
得分 0
添加一条评论
Changing settings from UE handsfree to UE stereo fixed the problem. Thanx heaps!
这个答案有帮助吗?
得分 0
添加一条评论
On my PC (XPS 15 running Windows 10), I was able to resolve the problem by going into Sound>Manage Sound Devices. There I found two UE BOOMs: headphones and headset. I disabled headset and then selected “Headphones UE BOOM 2 Stereo” in the volume pop-up menu and it worked a charm. Hopefully this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emerson_Wilmot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 38
总计 26,986
