跳转到主内容
Repair and disassembly guides for guitar amplifiers.
71 个问题 查看全部
no power on fender princeton 112 plus
I turned on my amp and no power. Have checked on/off switch, (good), capacitor, no power coming out. (Basler BE 2526901, PO 29668; 695-9801; no longer listed on company parts charts).
Does anyone know a replacement part for this part? Amp selling in my area is going for $130.00 or so. Is it worth trying to fix?
Thanx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@fita1200 start by checking the fuse to make sure that you have continuity. If you do and you have power on there, check the test points on the board (TP) to see where you are showing power etc.
You said that "Have checked on/off switch, (good), capacitor, no power coming out." It will help if you tell us which capacitor you checked and how you determined it was okay. Also, why you were looking at a specific capacitor. Post some good images of what and where you are measuring with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Les 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 426
