跳转到主内容
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
Why can't I go to system settings?
While trying to get into system setting on the DSi, I come to a screen that says, "An error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help troubleshooting."
The response in the operations manual says, "Turn the power off for a moment and then turn it back on. Repeat whatever you did that caused the error to occur. If the same message appears, the system must be inspected. - Turn the power off, and contact Nintendo Customer Service."
After 45 mins on the phone explaining the problem, Customer service wanted me to send my system in for repair. I want to know if there is an alternate solution that I can try to get my system fixed without sending my DSi through the Mail. Basically I want to fix it myself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
There are many rumors about various ways to hard reset these. I have tried them all on more than 1 system. To date nothing works YET. The most feasible and economic solution to your problem is to replace the motherboard. You can find one here, for about $70. Instructions for replacing it are here. Then sell your bad board on eBay to recoup some of the money. This is much cheaper than sending it to Nintendo for the repair. If you can find a way to repair this short of board replacement or sending it to Nintendo for repair please let me know. My contact info is on my profile. Thank you for coming here to find a solution and have a wonderful day!
The 133 MHz motherboard includes 256 MB flash memory the DS Game Card Slot, DC-in, and the audio in/out ports and the ABXY, Start, and Select buttons.图片
产品
Nintendo DSi Motherboard
$69.99
这个答案有帮助吗?
得分 2
添加一条评论
I dont get an error code, i get a blank screen. What do i do?
这个答案有帮助吗?
得分 0
2条评论:
Eric Longnecker, this question is way over a year old and not to often visited. Unlike other forums, here the answers are individual. If you need an answer for a problem with your device, use this link and give as much information as you can. It will take a bit more than one sentence to get proper advise :-)
完成的
Replace your motherboard or reflow the memory and processor chips.
完成的
添加一条评论
添加你的答案
weitmeyerj 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 8,803
