跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
iPhone 4 Frame replacement
Hey Guys
I would like to make my iPhone transparent but I don't know how to replace the front Display Frame and the Back Cover Frame. I want first to take out the display than remove the Frame from the Display than remove the black color from the display and finally to put the frame again on the display. Do someone know how i can do this and what things i need to do so?
Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You haven't understood I know these Repair Manual but I want to replace the frame that is glued to the Back Cover (http://www.sw-box.com/Iphone-4-Supportin...)
完成的
添加一条评论
7个答案
已选择的解决方案
Giuseppe, why don't you just buy it. They have it readily available and you could follow the teardown guide to exchange the parts. Just remember that light leakage and camera performance will get worse with this. Good Luck
这个答案有帮助吗?
得分 3
添加一条评论
We do not have a guide for that repair because you will likely break your display. I recommend buying a complete part and avoid the frustration.
这个答案有帮助吗?
得分 2
添加一条评论
Well ifixit has a step by step on replacing the rear back panel so replacing the front shouldnt be that much harder.
iPhone 4 后盖更换
Here is another website where they sell back covers for iphone 4.
http://www.sw-box.com/wholesale-Iphone-4...
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
I know that they are selling it but they have the transparent LCD only with an transparent Frame but i would like to make my iPhone 4 Gold and Transparent with white Frames and an White Home Button so i would like to buy the transparent parts from sw-box.com and change the Frame into White.
这个答案有帮助吗?
得分 0
1条评论:
Giuseppe, you can get the frame separately and get somebody to airbrush it for you. I think your best bet would still be the teardown guide and strip your phone totally then replace the parts with the ones that you want. If you buy the total kit then you have all the parts you need and paint the ones you want in a different color.
完成的
添加一条评论
just get this clear conversion kit: http://iphone4parts.com/clearkit save yourself time and hair
the supporting frame you are worried about is white so it should blend in and not be an issue.
这个答案有帮助吗?
得分 0
添加一条评论
now you see, i tried to do the right thing and bought it as a whole piece but who ever assembled it put the frame on the wrong way!!!
这个答案有帮助吗?
得分 0
添加一条评论
When it comes to a successful iPhone repair, there is only one company that you should use and that is iPhone Repairs Direct. Our iPhone repair service has been operating since September 2007. http://www.iphonerepairsdirect.co.uk/
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 10,288
