跳转到主内容
加入维修社区 - 创建账户
In 2002, the third-generation model was introduced which saw the model move further up-market. Planned and developed under BMW ownership the third generation was to share components and systems with the BMW 7 Series.
Where is transfer box relay location?
No relay - control module behind battery
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Michael West what year and what model is this? What are you referring too with the "Transfer Box relay"? What does or does it not do?
完成的
Michael West okay so you found what you were looking for?
完成的
If it is a 4wd or AWD and you are talking about the transfer case, it is under the vehicle. They used to be between the gearbox and the rear diff. Now I suspect it is all electronic.
完成的
添加一条评论
1个答案
已选择的解决方案
If you are referencing a relatively new Range Rover up to 2012 model year, it does not have a Transfer Case relay in a physical sense. All T-case related functions are controlled by a Transfer Case Control Module. All functions once ran by a relay in older models (Say switching from low to high range) is now transistor controlled by the computer. I would suggest having the vehicle diagnosed by a technician using Symptom Driven Diagnostics (SDD) software to isolate whether the problem is Sensor, Switch wiring or actuator related.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Michael West 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 36
总计 1,731
