Where is transfer box relay location?
No relay - control module behind battery
If you are referencing a relatively new Range Rover up to 2012 model year, it does not have a Transfer Case relay in a physical sense. All T-case related functions are controlled by a Transfer Case Control Module. All functions once ran by a relay in older models (Say switching from low to high range) is now transistor controlled by the computer. I would suggest having the vehicle diagnosed by a technician using Symptom Driven Diagnostics (SDD) software to isolate whether the problem is Sensor, Switch wiring or actuator related.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 1,321
3条评论
Michael West what year and what model is this? What are you referring too with the "Transfer Box relay"? What does or does it not do?
由 oldturkey03 完成的
Michael West okay so you found what you were looking for?
由 oldturkey03 完成的
If it is a 4wd or AWD and you are talking about the transfer case, it is under the vehicle. They used to be between the gearbox and the rear diff. Now I suspect it is all electronic.
由 sm_vulkus 完成的
