跳转到主内容
加入维修社区 - 创建账户
OnePlus 5 (OP5) 是一款于 2017 年 6 月 20 日发布的第五代智能手机。它是 OnePlus 3T 的继任者,也是 OnePlus 5T 的前代产品。
Front camera is not working
Front camera is not working. What can I check?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Help me too please my front camera not working
完成的
Which method can I use to see anything downloaded causing the front camera not to work,can I get to know that tricky please
完成的
Hi @Fridah,
Not sure with your phone but open the 'Settings' app and find Applications (Apps) or Applications Management in the list of settings.
Tap on it and then swipe the screen to the left to find section called "Downloaded".
In there is a list of all your downloaded apps. Tap to enter.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Start the phone in safe mode and check if the camera works OK.
If it does then a downloaded app may be the cause of it not working in normal mode. The trick is to find out which one.
If it still doesn't work OK in safe mode, perform a factory restore using the phone's factory restore feature.
Backup the phone first before doing this as a factory restore will erase all your data and downloaded apps. It will restore the phone to its' factory default condition. It will be like when you first bought it..
Once the factory restore has been completed, check the camera operation.
If it is still faulty then the camera needs to be replaced.
If it now works OK, restore the phone from the backup made earlier, using the phone's restore feature.
Once the restore has been completed, check the camera operation.
If it still works OK then the factory restore (or hard reset) has resolved the problem
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Scott Mantai 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 30
总计 12,912
