跳转到主内容
加入维修社区 - 创建账户
惠普于 2011 年至 2013 年间销售的主流台式机系列。
The problem with the file
Hello, everyone. I have a problem. My Outlook file created in 2007 version of the program was corrupted in some incomprehensible way. I contacted Microsoft technical support and they were unable to help me solve the problem. I get an error message that the Outlook data file PST corrupted, use the repair tool Inbox (SCANPST.EXE) to diagnose and fix errors in the data file. However, this did not help, I tried twice, useless. Can you here your advise, anything??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi, maybe I can help you, there was a similar problem , there is a very good microsoft outlook repair service. it helps to solve the problem quickly and efficiently
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi @underwoood
Where is your outlook data files located? C Drive?
and what is the current size of the outlook pst file?
Consider doing a chkdsk C: for any possible disk issues / bad sectors / orphan files.
you mentioned you use scanpst? any errors message you encoutered?
what operating systems are you using?
这个答案有帮助吗?
得分 1
添加一条评论
Did you use the scanpst in <disk drive>:\Program Files(x86)\Microsoft Office\Office12? If you have other folders for Office13, Office14 or Office15 those refer to newer versions of Office. You said that you are trying to fix a PST created with Outlook 2007, are you using that version or a newer version?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stephen underwood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 31
总计 394
