Left ear side not working!
It only works when i twist the cord. I disassembled the left ear but there are no loose wires.
Sounds like the wire is broken inside the cable and thus you have a loose contact. There are really only two options to fix this:
- find the approximate location of the broken wire, cut it out and mend the resulting two ends together
- replace the whole cable altogether
这个答案有帮助吗?
Continuity test from speaker to jack to find the break, or as mentioned, replace the whole harness.
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 1,800
Also the left ear will work if i twist the jack
由 Jannaeus Gabinete 完成的
