跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
No power from DC.
I was using this laptop and the power died. I realised that it had been running on the battery although the DC mains cable was plugged in. The battery had run out of juice.
There was no DC power LED on indication
I have tested all the obvious things, and have now replaced the DC cable and socket with a new one.
However when I plug it in I still get no DC power LED on indication. Currently the keyboard is removed and I haven't bothered to put it all back together as there doesn't seem any point.
Does anyone know what to try from here ?
Many thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@oldturkey03 the DC power adapter chucks out 12v. This is still working.
完成的
usually dc output is 19v is it not
完成的
yes, 19v. I think I'm using the wrong adapter. so much for "I've tested all the obvious stuff". Thanks for the wake up call, dang.
完成的
添加一条评论
1个答案
最有帮助的答案
@sponge_bob you wrote that you "tested all the obvious things," but did not tell us what the output of your AC adapter is. Should be a 19V 65W adapter
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sponge Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 28
总计 353
