跳转到主内容
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
Can't get my ignition to turn with the key in it?
tried to wiggle the steering wheel and the gear shift
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If this has been answered already it may still be of help to someone else.
However, ignitions tend to wear out over time. Either a spring or a part inside them breaks, misaligns or just plain fails. In that case a new part is required, and will need to be fitted. That is the only option, although a quick solution is to put the key in but do not rotate it, give it a sharp whack with the base of your hand. Then try and turn it. Some times this moves things enough to get the key working. It is a stop gap solution only.
这个答案有帮助吗?
得分 1
添加一条评论
If the steering wheel is locked into position the key will not turn. The solution is not to wiggle the steering wheel, but to tightly grip the steering wheel and firmly try turning the steering wheel to the left then try turning the key. This will allow the steering wheel locking mechanism to release locking pressure and free the ignition.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mary Jane Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 178
