跳转到主内容
加入维修社区 - 创建账户
Signet 系列是柯达在 20 世纪 50 年代推出的顶级美国制造 35mm 相机系列。它是仅有的两款配备测距仪的 Signet 型号之一,也是唯一一款主要材质并非塑料的机型。
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
添加一条评论
1个答案
已选择的解决方案
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 分光镜更换. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
这个答案有帮助吗?
得分 3
3条评论:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
由完成的
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
由完成的
Thank you very much
由完成的
添加一条评论
添加你的答案
Florentin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 784
