跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Can I use tape instead of adhesive strips when replacing the battery?
I didnt realize you had to buy adhesive strips when also buying a new battery. I am desparate however and dont want to wait another week for the adhesives to come in. Can i use double sided tape instead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
已选择的解决方案
@lehud like @benjamen50 already said, yes you can. Any good hardware store will have double sided tape you can use. It does come in a variety of thickness and something like 3M 4624 will work. Not as convenient as the strips offered by ifixit but good enough to hold your battery in place.
这个答案有帮助吗?
得分 6
添加一条评论
You can use double sided tape like this, it works great for adhereing batteries:
https://www.ebay.com.au/itm/50M-PET-Tape...
这个答案有帮助吗?
得分 3
添加一条评论
Most double sided tape is to thin to gap between the battery and case. Best to wait. Sorry ;-{
这个答案有帮助吗?
得分 2
2条评论:
What do you mean? Are they not strong enough?
完成的
Try this take two large coins and place the tape between them you could pull the coins apart quite easy as only a small amount of surface contact. Now take two frame washers of the same size while it still has a hole the surface area is larger than the coins. It will take more effort to pull them apart.
Your battery and case are similar to the coins. A foam or thicker tape will form to the uneven surfaces. You really need to hold the battery down otherwise things can get worse!
完成的
添加一条评论
I'm more concerned of the heat on the foam when the battery gets too hot....will the have an effect?
这个答案有帮助吗?
得分 0
添加一条评论
Does Ifixit handle a screw kit that holds tthe battery connector down? i somehow lost the little screw on my ipone 6S
John Boehm
jboehm@yahoo.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LeAnne Hudson 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 34
过去 30 天: 169
总计 19,641
