hdmi out port broken
My question is I broke the inside HDMI port for TV output from my Xbox one. Is there any Alternative way to play my xbox some how until I can have it fixed? Will a usb to hdmi converter work?
First off, no - an HDMI to USB won’t work. Depending on the damage, you will need to replace the HDMI connector on the console which is a surface mount job. Much like the 360, the One does not turn on without a good HDMI connection and this has likely carried to the revised systems.
The guide needed for motherboard removal can be found here. Once you have the board out, see if it is something you need to send off to someone more capable or if you can handle it.
If the port looks okay, you will need to check the components around the connector and the HDMI IC. These can be damaged when HDMI is “hot plugged” without turning the device off unless the device is designed to do it safely (ex: laptops) unlike Composite and Component. The location varies based on the console revision you have (OG/S/X) but in general this is where it will be:
(One X?)
(One S)
The part number for the One S (based on the device selected; use common sense for the OG and X) is 75DP159. The One X being a 4K console will use a different part then the OG and S by the nature of the hardware upgrades.
这个答案有帮助吗?
Can whoever downvoted it come forward and tell me what's wrong with this? I can't improve it correctly without knowing what went wrong...
Without the downvoter coming forward, I can't do much more to fix this answer.
@nick looks like a valid answer to me :-)
@oldturkey03 it was probably someone who decided to waste points on a questionable downvote.
I need help with my Xbox HDMI not coming on
这个答案有帮助吗?
I can help you out possibly. Does the port look damaged in any way?
What tools are best to use to remove HDMI port from xbox one S. Having trouble. Short story my dog knocked xbox off shelf broke the inside of port which part of it is still in the HDMI wire.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 52
过去 30 天: 199
总计 40,935
