跳转到主内容
Repair guides and support for the Galaxy E7, an Android smartphone released by Samsung in early 2015. Features a 5.5" Super AMOLED 720 x 1280 display, a quad-core 1.2 GHz Snapdragon 410 CPU, and 2 GB of RAM.
Why won't my phone turn on?
I turned off my phone at 66% because my class had started. After class I wanted to check my phone but it wouldn't turn on. I took out the battery and pressed the power button to "drain the phone" but that didn't work. I then charged for about 10 min. and it still will not turn on. What is the problem?
Update:
I think the phone is on, but the screen won't work. If I get a phone call are a text message my phone will alert me, but I can't turn on the screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Aubriel Jensen possibly a failed display. you want to first charge it longer than 10min. If you have no results after having let it properly charge, I suggest you try a hard reset but do not reset it
Turn off your phone completely. (Press the power button for few seconds and tab on Power Off)
Press and Hold Home + Volume Up + Power keys together at the same time about 10 seconds.
As soon as you get into the Android system recovery mode, go to wipe data/factory reset using the volume down button and select it with the power button.
When asked to confirm “Confirm wipe of all user data?”. Select NO
Select reboot system now.
If your phone did not show anything on when you tried to reset, consider replacing the display.
这个答案有帮助吗?
得分 2
1条评论:
it worked...thanks
完成的
添加一条评论
Try TESTING a different charger. If it works with a different charger, then you need a new charger.
Or Go to a service center and replace the charging panel
这个答案有帮助吗?
得分 0
2条评论:
I tried it.... It didn't work
完成的
did not work
完成的
添加一条评论
添加你的答案
Aubriel Jensen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,387
