跳转到主内容
9th generation of Chevrolet's full sized SUV, based on the GM GT800 platform.
30 个问题 查看全部
Oxygen sensors location places
Locations of oxygen sensors on a 1996 chevy c1500 5.7
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@symphony2627 best to see and to get to with the vehicle on a lift.
Oxygen sensors bank 1 is any sensor upstream the catalytic converter and bank 2 is downstream. you'll have one before and one after the catalytic converter. Even so the attached image shows a dual exhaust it also applies to single exhaust but will of course only have two sensors. This video might help you further.
这个答案有帮助吗?
得分 2
3条评论:
Am curious why the site says this answer was unaccepted... seems like it shows exactly where they are...
完成的
Probably because it is incorrect.
Bank 1 and Bank two refer to the primary exhaust pipes coming off each exhaust manifold.
On this vehicle, and any GMT800, Bank 1 refers to the Left or Driver's Side; Bank 2 refers to the Right or Passenger Side.
Sensor 1 and Sensor 2 are also called the Upstream and Downstream sensors.
Sensor 1 is the Upstream sensor and is located before the Catalytic Converter.
Sensor 2 is the Downstream sensor and is located after the Converter.
完成的
@Charles Colfax looks like that is what the answer says.
完成的
添加一条评论
添加你的答案
Wendy Elliott 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 105
总计 7,402
