跳转到主内容
Repair guides and support for a wide range of Vespa scooters.
15 个问题 查看全部
Vespa steering column lock removal.
Hi I have removed the steering column on my Vespa LMR Star . But I can't get the steering lock out as I need to replace as the keys are lost. Do I knock it out or is there another way to remove it . I would appreciate any advice you can give me thanks Gerry.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Gerald Murphy LMR or LML Star? If it is LML Star then it will help if you give us the model number as well.
完成的
添加一条评论
1个答案
最有帮助的答案
Gerald Murphy it should be riveted in. Post some images of your lock etc. with your question so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. See if this video looks like your lock
这个答案有帮助吗?
得分 1
1条评论:
Thank's for your help much appreciated.Should have the bike on the road in time for the spring .Gerry.
完成的
添加一条评论
添加你的答案
Gerald Murphy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 670
