跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
71 个问题 查看全部
Does anyone make a MicroUSB cable that works well with this controller
I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.
While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.
The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)
Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
How about soldering in a braided wire? https://www.amazon.com/dp/B012A1221Q/ref... just chop the micro USB connector off the end of this one.
Update (02/01/2018)
Actually, Here's a braided one for xbox 1 controllers. why braided? from my experience it extends the life of my apple cables soooo... https://www.walmart.com/ip/Microsoft-Xbo...
这个答案有帮助吗?
得分 1
2条评论:
@nick not sure or not if you get a notification for updates, so here's this.
完成的
I'm not sure if Microsoft does the same thing they do with the Elite cable as they do with the Play and Charge cable. I doubt it, but I've never seen anyone with one yet to verify that.
完成的
添加一条评论
The ones on monoprice.com are really good and come with a lifetime warranty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 2,356
