跳转到主内容
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 个问题 查看全部
2006 Ford Ranger 3.0 6 cylinder compression leak.
I just purchased a 2006 Ford Ranger with a 3.0 6 cylinder. It has 73K I was told it had a misfire in cylinder six. I purchased it for a good price and have a about $1000 to put in to the truck. I just found out that cylinder 6 has a compression leak. I don’t know the readings yet(compression numbers). After driving it a few days it has a lot of power, it idols relatively smooth and it seems to have a lot of power. It’s not using or leaking any fluids. I’m just not sure if I feel comfortable driving this truck knowing that it has a compression leak. Do you have any suggestions? I have some experience fixing cars but I don’t feel comfortable changing heads or engines. I do have a friend that works cheap.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@rigs2 all this will depend on what your compression test shows. If it does show low compression you do want to make sure that your valves etc are okay. The best thing to do would be a leak-down test.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Riggle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 367
