My screen went half black and half rotating colors
Hello , My LG tv (Model 60UF7300) is only about 2 years old. While watching, the screen started to have horizontal lines through it. I pressed the tv input button and the right side went black while the left side stayed colored (rotating from blue to green to purple) and there is no response to any buttons on remote. Has anyone else had this issue?
9条评论
Hello,
@oldturkey03 and @stacyk
I have same problem with my Lg tv 43 inch LED 4k.
Is your TV working fine after changing TCON board. I highly appreciate if you can reply.
Thanks
chanpreet
由 Chanpreet 完成的
@chanpreet99 the tv still didn’t work once I had the TCON replaced, unfortunately. We ended up trashing it and getting a Sony
由 stacy koss 完成的
@stacyk thanks so much for your quick response.
由 Chanpreet 完成的
@chanpreet99 you’re welcome. Best of luck, I hope yours works out better than mine did!
由 stacy koss 完成的
@stacyk I want to share my experience.
I replaced TCON board, still same issue.
Then I replaced TV main board which fixed my TV issue. hope this will help someone who looking for resolution.
Thanks to all.
Resolution : TV main Board faulty
Thanks
Chanpreet
由 Chanpreet 完成的
显示更多的4条评论
