跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z3 是一款 2014 年发布的 Android 智能手机,以其出色的电池续航时间和耐用性而闻名。
Changing the digitizer / Lcd
Ok looking at changing the digitizer on the d6603, Question is this: Is the Lcd screen bonded to the digitizer and has anyone got a work around/way of separating the 2? or are the not bonded for sure?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
yes the glass is bonded to the lcd its not expensive for the full lcd so i would replace the whole thing
这个答案有帮助吗?
得分 2
6条评论:
由完成的
That's what I thought though its a fair bit cheaper just to do the digitizer, Any experience of separating one yourself?
由完成的
only with samsung, if you take the whole lcd out you could use lcd cutting wire and a hairdryer or heat gun but you would need a way of holding it down while cutting, i use a vacuum seperator so its alot easier
由完成的
maybe it isnt bonded just watched another video there but it skipped parts. https://www.youtube.com/watch?v=8WhrZnJ4...
由完成的
I do have a reflow machine for other work I do. Lcd cutting wire? Could be subbed for a fine fishing wire? Cheers Daniel will give that a look now, I know the z1 wasn't bonded totally but partially at the bottom from what I remember a few moons back
由完成的
显示更多的1条评论
添加一条评论
Change the complete lcd. Pretty simple job. If you get the lcd without the frame be sure to adhere properly on the sides. They tend to lift easily and you will be able to see the light through the space on the lcd and frame.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zerocool278 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 534
