跳转到主内容
Guides and support for various television (TV) brands and styles.
9052 个问题 查看全部
Disassembly and Repair Philips 37pfl9604h/12 Black and negative screen
Could someone help me with pictures of disassembly of the Philips 37pfl9604h/12. Also if you have to remove the footh first and how.
Problem is:
The screen is at the left side normal but on the right side slow, and negative, and black.
Questions:
How do i disassembly this tv
Could anyone tell me which part it could be? I heard already things like the ribbon cable, the TCon, or the AUO
Could anyone tell me where i can buy this parts, of let it repair if its too small work or soldering work?
Thanx in advance
I thought you have to take of the footh first to disassembly the tv, thats why i asked that, if it’s possibly without , then also good:-)
Hereby the pictures
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@ti080 I am a bit confused by your question. "to remove the footh first and how." referring to the stand? "The screen is at the left side normal but on the right side slow, and negative, and black." can you post some images of what that looks like with your question? That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that
Yes it could be all of the parts that you already listed but unless we can see it and you check a few things it is hard to determine.
完成的
添加一条评论
1个答案
最有帮助的答案
@ti080 looks like you can do this without removing the foot.
Philips is a bit different since most of their service manuals go by chassis number. yours should be a Q549.2e La It'll help us if you could verify this against the label on your TV.
Yes it could be all of the parts that you already listed but unless we can see it, and you check a few things., it is hard to determine.
这个答案有帮助吗?
得分 1
5条评论:
Thanx i put the pictures in the original message, so you can see what sort of screen i see:-( hope you can help me solve the problem. Excuses it took a bit of time, but i was not able to fix or answer
完成的
@ti080 looks like some failed backlight LED's. You will have to disassemble the panel and check those out.
You will also have to take a good look at the main board as well. The center darkness looks like a backlight issue. There seems to be some "confusion" on the whole picture. If possible post an image of what the display shows without a menu etc. Right now it appears very "cluttered"
完成的
thanx chassisnumber is right as you discribed
完成的
How can i see after disassembling if it's the panel? or what it is else?
完成的
start with the power board first. make sure that you have the voltages going to the LED's in the panel. If you do then you can pretty much rule in the LED backlight strip.
完成的
添加一条评论
添加你的答案
tini 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 614
