跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
What's that squealing noise?
I have a 300D that makes a squealing noise, similar to a drive accessory belt. I replaced all 3 belts with high quality ones with no change. I later noticed the noise was much worse when I was using electrical systems with large draws (headlights, heat, A/C). I replaced the alternator and it seemed to do the trick for about a week, then it started again. It doesn't make the noise until it's above an idle speed, and when it does, it's impossible to diagnose where it's actually coming from just from the sheer volume. Has anyone here experienced the same issue (and figured it out)? Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Sounds like you may have a pulley wheel trying to lock up or bearing failing.
这个答案有帮助吗?
得分 2
添加一条评论
joshuaahopkins that is one of those where you could be chasing the rabbit down the rabbit hole. Let's make the assumption that this is not caused by your alternator. You do want to make sure you have the right belts and that the belts are not riding to high. Adjust the belt tension properly. Let us know if the squealing is different if you turn the AC on/off. Check all the pulleys since I seem to remember that they do not have a Woodruff key holding them on the shafts. Check all those pulley bolts. Remove your belts separately to see if that changes the noise. I do believe it has separate belts for power steering, AC and alternator which should at least get you a bit closer to where the noise originates from. and check the bearing by moving things by hand. Use a mechanic stethoscope to see if you hear any grinding etc. See if you can feel any grinding or have some wobble when you move those. The squealing on my 1982 240D was caused by a bad water pump bearing.
这个答案有帮助吗?
得分 2
添加一条评论
Tensioner pully or guide pully.probably but not gaurenteed
这个答案有帮助吗?
得分 0
1条评论:
shawn does it even have a tensioner pulley?
完成的
添加一条评论
I'll bring my stethoscope home and see if I can get closer this weekend. Thanks everyone!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joshuaahopkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 3,257
