跳转到主内容
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
51 个问题 查看全部
How to switch off red LED during video recording in Nokia N8?
During Video recording the red LED on the side of the flash in Nokia N8 lights up which is annoying if you are facing the camera.
There is no option to disable the red LED. How should I disable it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
I believe that this is done through the settings menu. Go to Camera Settings and Turn of the Macro Option. I beleive that your setting allow you to turn it to automatic, this would turn the LED on during darkness only. Here is a great place to learn more about your N8. Good Luck to you...
这个答案有帮助吗?
得分 3
添加一条评论
I'm pretty sure thats so people know you are recording so you are not recording against their will. My Nokia N900 has the same thing.
这个答案有帮助吗?
得分 1
添加一条评论
As far as i know that option is disabled in some countries for privacy protection reasons. If you dont have the turn off option in the menu you simply cant do it. Same goes for the "click" sound when you take a picture.
这个答案有帮助吗?
得分 1
添加一条评论
record a video in close-up mode the red led will not light up, if it still does then zoom in and zoom out 2 or three times it will turn off.
Hope it helps you
这个答案有帮助吗?
得分 0
1条评论:
zoom out zoom in
or
close up doesnt worked for me :(
完成的
添加一条评论
turn on camera with close-up , then start recording, close the obiectiv with you finger and turn max zoom then normal zoom . At my n8 it works every time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
smulam2002 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 10,673
