跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Wireless Controller doesnt work [PC]
So Ive had my current Xbox wireless controller for a few months. Everything worked perfectly until 10 minutes ago. It suddenly stopped working, no buttons were registering. The problem is that my PC recognizes the controller, the xbox light on the controller itself is on, if I plug in/out the usb reciever, the windows connect/disconnect sound goes off but if I go to controller settings where you can calibrate it etc, no buttons are registering no matter what I press. The controller itself works, tried it on another PC and it works normally.
Any advices what to do? I've already reinstalled the drivers, tried switching USB ports but nothing works
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is (unfortunately) a very common driver problem on Windows 7/8.x systems. It doesn't happen on Windows 10, but 7 and 8.x are known for this problem. Windows 8.x is nowhere near as bad as 7, but it still happens. I’ve described the fix here: troubleshooting Wiki.
The fix for these systems is to manually install the driver. The 1708 is new enough I'm hesitant to recommend the .exe driver (it’s ~5 years old). The Update Catalog driver is much newer at this point. While it’s clear Microsoft will never improve the situation, my W7/8.x fix is permanent; just don’t remove the driver and apply the fix right away if you replace your system or reinstall.
If you continue having problems, try using the controller over MicroUSB. If you have better luck, there may be a fault with the controller on the IR or Bluetooth** side.
**Bluetooth only works in Windows 10
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
taura 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 2,665
