跳转到主内容
Repair guides and support for your Samsung TV.
2612 个问题 查看全部
Thick shadowy black/green vertical line
Hi,
I've got a thick black/green line that goes top to bottom on the left side of my screen.. it's not solid, it's like a shadow. You can only see it on certain pictures, it's particularly visible on a blue sky. Or solid colour background.
Anyone know what it might be?
TV is a Samsung hu7200 65". It's about 2.5 years old..
Thanks
David
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@huskymanwhat you have here is a broken panel. Check the crack lines etc. There is no repair for it but it will have be replaced.
The major issue will be to find a replacement. If you can find it, it will most likely cost more than a new TV. You could check places like ebay or craigslist to see if you find the same make and model TV as yours that is broken other than the display. Then harvest the display from that.
这个答案有帮助吗?
得分 1
添加一条评论
It is probably just that some of the pixels on that side of the screen are not registering some colors so you will probably have to replace the LCD.
这个答案有帮助吗?
得分 0
添加一条评论
I have a ibell b LED TV and their is a horizontal green line at the top of the TV please tell any solution
这个答案有帮助吗?
得分 0
3条评论:
@akshay123 you'll have to post a "clear" image of your complete screen.
完成的
Ok, but the green line appear in half hour when i start the tv
完成的
I have a ps4 when i was playing i saw a green horizontal line at the top of the tv can anyone sayis their any problem in ps4
or in the tv
完成的
添加一条评论
添加你的答案
David Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 4,636
