跳转到主内容
加入维修社区 - 创建账户
Asus ZenWatch 3 的维修指南和故障排除。这款智能手表使用 Wear OS 操作系统。
Crown does not working (mid)
My watch works perfect, but the Crosn button is not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
I had the same problem so took the watch apart with a torx 4 and discovered that the plastic press that the crown pushes against was cracked so being the handy feet thinking female that I am I repaired this by glueing a fragment of false nail over it (with nail glue)
And now reassembled it works perfectly fine
这个答案有帮助吗?
得分 2
添加一条评论
I tore the watch down to look at how the buttons work. While the others distinctly click, the middle/crown button felt mushy. I found that if I applied pressure to the circuit board while pressing the crown button, it would click. I put the watch back together and found this to still be true. When the crown button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it works. Not an elegant fix, but it works.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sandro 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 36
总计 1,170
