跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
My remote works sometimes
Okay so I’ve had this TV for about a year now and it was working perfectly fine up until last month. The TV works perfectly but it won’t respond to the remote. The only thing I can do it turn my tv on, and sometimes I can’t turn it off, I’d have to turn it off manually. I’ve done research and I did what I was told. And nothing worked... my remote recently just started working again for like a week and now it’s back acting retarded.. I need answers ASAP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
have you tried changing the batterys?
完成的
Have you solved this? My remote has been on the fritz this last week and I’ve changed the batteries and reset my tv with no solution
完成的
添加一条评论
1个答案
最有帮助的答案
Torian Terry I am sure that by now you have this fixed already. So this is just for completion sake. I would start off with a new remote since this could be remote related. If that does not fix it then you are looking at having to replace the IR board on your TV. Since we do not know the model etc. we cannot provide you with part numbers etc.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Torian Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 720
