跳转到主内容
加入维修社区 - 创建账户
Samsung CLX-3175FN 维修指南及支持,这是一台集传真和复印功能于一体的多功能彩色激光打印机。
Toner Waste Bin Error message
I removed and replaced the Toner waste Bin and now I get an error message to "Replace/Install Toner Waste Bin." How can I clear this error?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Check it's seated properly.
这个答案有帮助吗?
得分 0
2条评论:
This made no difference.
由完成的 分享
Empty it, rinse it with water, dry it out well and refit it
由完成的 分享
添加一条评论
最有帮助的答案
Please check whether the clear plastic "windows" in the bottle side are clean. The system "sees" the toner level through those "windows". Try and keep them clean (otherwise the system will think the bottle is full of waste toner). Take care NOT to blow, you would spill toner everywhere! Gently tapping the bottle on a hard surface is usually sufficient.
这个答案有帮助吗?
得分 1
1条评论:
You may need to clean the inside, I've used a few drops of laundry detergent and let it sit for around 10 minutes then washed it out in the bathtub and poured a bit of 99% rubbing alcohol, let that sit, washed that out, put it back in, and all good.
由完成的 分享
添加一条评论
添加你的答案
Kerry Ross 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 1,414
