跳转到主内容
加入维修社区 - 创建账户
Asus X55C 发布于 2012 年底,是一款 15 英寸笔记本电脑,屏幕分辨率为 1366x768。它内置 Intel 处理器,并采用 Intel 集成显卡。
Computer just blacked out.
Not sure if it's connected, but my sister just put a connected Micro USB into the USB port of this PC that I've had for quite a while. At that moment it just went out, no indication of life, no lights turning on. Checked that the charger is just fine. I'm not sure if connecting the Micro USB trough the wrong port to the computer itself can break it, but it seems the only logical case. I'd understand if it went out of old age, but it just happened instantly. What could have happened here? Is it the USB or possibly something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
The metal jacket around the micro USB may have shorted out the +5VDC power supply to the USB port and also it may have affected the USB controller by connecting +5V to it as well on the USB data lines. I don't know why it would affect the rest of the laptop and not only the USB ports and USB controller though.
Perhaps the whole +5V supply in the laptop (derived from the battery (or the adapter) may have been affected.
The laptop has various power supply rails of different voltages in it.
You may have to open it up and check if you can see any obvious signs of damage. Hopefully perhaps only an onboard fuse (or fusible link) may have been blown.
If this is the case once the +5V is restored it may work again, but possibly not the USB ports as no doubt the USB controller would have been fried.
这个答案有帮助吗?
得分 2
添加一条评论
Was it just connected to something or was it like some sort of flash drive?
这个答案有帮助吗?
得分 0
5条评论:
The USB was connected to the computer and the Micro USB was put into another USB port.
由完成的 分享
Have you tried charging the battery for ~24 hours or so?
由完成的 分享
Yes, still no signs.
由完成的 分享
So you plugged the computer into itself with a USB cable?
由完成的 分享
With a Micro USB, it wasn't even a compatible port.
由完成的 分享
添加一条评论
添加你的答案
Julijus J (Laujas) 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 25
总计 517
