Battery Replacement for Chromebook
Please let me know how I can change my Chromebook Pixel 2 (2015) battery
Buy a Li-ion Genuine Battery For C1551B 7.6V 70.6Wh 9295mAh on Ebay and replace the battery.
I’ve successfully changed my Pixel’s battery: Open Pixel according to iFixit description, unplug the old battery, use a hot air gun to soften the sticky pads and remove and replace it with the new battery.
这个答案有帮助吗?
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 19
总计 1,933
1条评论
If you heat up the battery enough to loosen the glue, the battery just starts crinkling up. LOL.
Heat up one side first and pry up the end battery. Once that is up, you can put your heat gun underneath a 2" putty knife as you pry it off.
Aside from the glue, it's an easy job. And the batter is unblocked by any parts.
由 Harry Slaughter 完成的
