跳转到主内容
加入维修社区 - 创建账户
Mr. Christmas Inc. 音乐节日装饰品支持。
Diode on board blew need replacement.
Diode D4 I don’t know anything its about and what to use to replace it on the board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,@kilgallon
good day, take some pictures for us to see :)
hopefully we are able to see the values. :P
完成的
添加一条评论
1个答案
What kind of device is the blown diode in?
Send us the model number and brand with some pictures so we can help you out
这个答案有帮助吗?
得分 0
5条评论:
Hi @troyj ,
FYI the device "usually" can be found by viewing the image to the right of the OP's question. That information is supplied by the OP when they fill out the ifixit ask a question form. As to the model number that is always a problem as a lot of people forget to add that info in their question so it always has to be asked of them, which slows down the process.
Cheers.
完成的
So y reply to my question?
完成的
Hi @troyj ,
I replied to your question because you asked "What kind of device is the blown diode in?". In the second sentence you ask what "brand". The "brand" and "device" information had already been supplied by the OP.
Because of this I thought that perhaps you might be unaware of where to look to find this kind of information in a question.
"Mr Christmas Musical Carousel" says it all as far as brand and device goes, but admittedly not the model number..
完成的
Thank you.. but answer the gentleman's question
完成的
Hi @troyj ,
I'm waiting for his response to both @salmonjapan 's and your request to supply pictures of the diode in question and perhaps the pcb as well.
Up until then I'd be only guessing as to the rating of the diode.
Although It may not be that critical as the power supply for the device is only 6VDC.
So I guess a standard IN4001 would get him out of trouble, (if it would physically fit that is and the pcb was hole through and not smd), but there is always a reason why a component fails, especially if it "blows" (according to the OP). This suggests that there may be other problems that might have caused this to happen.
完成的
添加一条评论
添加你的答案
Rob Kilgallon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 416
