跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
56 个问题 查看全部
Why is my 5 speed 1993 xlt stuck in gear
Why is my f-150 5 speed xlt
hung in gear
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
1993 f150 stuck in gear
完成的
Clutch is ok, slave cyl. was leaking down got that fixed, 165000 mi. think my nephew crammed it in gear while cyl. was weak. I am feeling like the shifter has jumped track or broke. I think I can take shifter up from floor to see. My question is can I fix it that way or do I have to take trans. out of the truck. Thanks for responding.
完成的
添加一条评论
1个答案
已选择的解决方案
Johnny Johnson you definitely can remove the shifter with the transmission remaining. Actually you will have to remove the shifter to drop the tranny. Here are the instructions from 1980-199 Ford Pick-Ups. Typical Haynes, kind of crummy but hope it'll help you out.
Since yours is a 5-speed and you did not mention anything about OD, I added the manual for the Mazda S5-42 ZF Transmission Mazda_Ford-ZF-S5-42-Transmissi.pdf
这个答案有帮助吗?
得分 5
2条评论:
Thank you very much I will try this , I will need this.
完成的
Johnny Johnson you are welcome. BTW great truck and those are real workhorses. Keep it going....
完成的
添加一条评论
添加你的答案
Johnny Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 3,736
