跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
MacBook Pro 15" mid 2014 suddenly shuts down
Hi,
So, my MacBook Pro has had this issue for a good while. I just picked it up again after 4 months of collecting dust, to see if its possible to fix it.
We´ve tried changing the heatsink without results. Or at least positive results.
I can be surfing in safari or playing CIV V which is the hardest thing this machine has ever done - and it suddenly shuts down without warning. I tried stresstesting it today both CPU and RAM and nothing happened, until the stresstest was finished, then it shut down. And then i can start the MacBook again, and it shuts down after a minute, or it can take an hour.
I´m kinda lost here, all help or propositions will be appreciated.
It is a 2.5GHz with 16GB and 256GB SSD
Update (04/27/2018)
So, I sent it to Apple.
They switched out the motherboard(In February), and it hasn't crashed once since!
Yay!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
10条评论
I would start by digging a bit deeper diagnostically. Get a good thermal sensor monitor app like TG Pro as well as this free app CoconutBattery post screenshots of the main windows of the apps so we can see as well.
完成的
I tried downloading said software but the Mac kept shutting down as soon as I opened safari. Took some screen grabs from console. I’ll see if I’m able to upload them.
完成的
Here’s screen grabs of console shortly after crash and reboot.
https://imgur.com/a/EXgZs
完成的
This is how it looks. Here the MacBook has been on for 5 seconds. After the screen goes black the fan starts working hard. 15 seconds later the light in the keyboard turns off.
https://imgur.com/a/xG6xe
完成的
hey @cstueland sorry I abandoned the question. never got a notification when you replied. @mayer any ideas on this?
完成的
显示更多的5条评论
添加一条评论
2个答案
最有帮助的答案
Did you reapply new thermal paste? if you remove the heatsink you must clean off the old thermal paste and reapply new thermal paste.
如何涂散热膏
更换MacBook Pro 15" Retina Display (2014年中)的散热模组
Electronics Skills图片
指南
如何涂散热膏
难度:
中等
5 - 20 minutes
MacBook Pro 15" Retina Display Mid 2014 散热器图片
指南
难度:
中等
20 minutes - 1 hour
这个答案有帮助吗?
得分 1
5条评论:
@captainsnowball - Aiden you'll want to re-read what he did:
"We´ve tried changing the heatsink without results. Or at least positive results."
You're not offering a useful answer here.
完成的
He did not mention replacing the thermal paste though.
完成的
Yes, we removed old paste and added new.
完成的
Screen grab from console.
完成的
完成的
添加一条评论
I had this problem with my mid-2014 15” mbp. Mine would pretty reliably shut down soon after opening a browser. If I opened nothing, or just copied files, it might go 30 minutes before shutting down. First screen would go black, then it would turn off after about 5 seconds. I reset NVRAM and SMC, no help. I did a clean install of OS X. No help. I had already replaced the topcase/battery on this machine a while back. This machine has seen extremely heavy use for the about 5 years I’ve owned it.
So because one of my fans would make a lot of noise under load (had been going on for months) I had already ordered 2 new fans. Was just procrastinating replacing those. So I replaced the old and very dusty fans and at the same time replaced the very old and crumbly thermal paste. Removed all the random dust bunnies from the inside. Put it all back together. Fixed!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 39
总计 2,597
