跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Target Disk compatibility Issues between a MacBook and an iBook?
I recently acquired a (free :) 1.2 GHz G4 12" iBook(v. 10.4.11), that has a blacked out screen. I'm pretty sure it is an inverter issue because I can see and some what navigate the computer from a very faint image. I do not have an external monitor to connect it to, so I figured I'll boot it from my 2.4 GHz (Penryn) MacBook 13"(v10.6.6) via Target Disk Mode to confirm my hypothesis and see what kinda shape the rest of the iBook is in. My Penryn does not recognize the G4's drive and vice versa, It doesnt even appear as a mountable drive in Disk Utility on either one (both of the Macs do successfully mount other types of external drives). I've tried several different firewire cables to no avail, and both Macs do successfully boot in Target Disk Mode. So either both of the Macs have the same issue of being unable to mount drives through Target Disk Mode (highly unlikely) or Apple dropped backwards compatibility between v.10.6.6 and v.10.4.11. Anyone have thoughts, explanations, or theories to address this issue before I start tearing down the iBook and possibly wasting money on parts I may not need. Any help would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
It should work, I've done it. What you can't do is install a system from one to the other because of the difference in processors. I have not done it using 10.6.6. I'm just fishing here but I would start the G4 in Target mode and the MacBook from the original installation disk and go to the second screen pull down menu to Utilities > Disk Utility and see if it see the G4 drive. If it does, then the problem is the 10.6.6. You are correct on the G4, it most likely is the inverter (because you can see the desktop). HERE'S THE FAST WAY TO FIX THAT: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
这个答案有帮助吗?
得分 2
2条评论:
For further clarification ... I'm not trying to install a different and/or newer OS on the iBook, I'm just trying to get a look at the iBook to see how she's running and figure out what else needs to be replaced or fixed. I've tried using my MacBook's installation cd's disk utility and my MacBook doesn't see the iBook. The old iBook is the one with the inverter problem not my MacBook, but that's not an issue, easy fix. But my issue arose when diagnosing the iBook I stumbled upon this target disk compatibility issue. Isn't the whole (or original) point of target disk mode to assist with transferring data from an older mac to a newer mac. So why cant my MacBook access the iBook's drive?
完成的
I was hoping this was a 10.6.6 issue, thus starting up from the original disk. Now I would have to suspect the firewire cable, or one of the firewire ports. Target mode should work. If you have any firewire device I would use it to test both machines.
完成的
添加一条评论
添加你的答案
samk2487 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,131
