跳转到主内容
加入维修社区 - 创建账户
Canon Rebel T4i 属于 Rebel 系列,是一款拥有 1800 万像素传感器和液晶显示屏的数码单反相机。它也被称为 EOS 650D 和 EOS Kiss X6i。
Resources for Memory Card Reader Replacement/Repair?
My Canon T4i has met with a terrible fate. (Majora's Mask, anyone?) As with many of its fellow T4i brothers, the memory card reader has pins that are mangled. In my attempts to realign them without opening up the camera body, via some picks through the slot opening itself, I managed to further the damge. As such, and not willing to accept defeat, and Gan...err... Canon's outrageous repair prices, I am in search of a comprehensive guide on how to replace the aforementioned card reader. Also, a trustworthy source of camera parts would be, as with any assistance offered here, greatly appreciated.
TL;DR
Card reader is broken. Need to find a new one and to know how to fix it. Made obscure Legend of Zelda references.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Unfortunately for the Canon Rebel T5i, the SD card reader is soldered directly onto the Main PCB board. You can find replacement SD card readers and solder on a new one, but this is very difficult to do unless you are already experienced with soldering.
The other option would be replacing the entire main PCB board, which would definitely cost more. However, an issue you may run into if you try replacing the main PCB board is that the board may then need to be recalibrated or the software adjusted in some way (in which case that would need to be done with Canon's service software).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cameron Shelton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 615
