跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2015 年 9 月 25 日发布的 iPhone 6s 维修信息与指南。型号:A1688、A1633
Inaccurate GPS while moving
Hello,
I bought used iPhone 6s in perfect condition, but I've got problem with it. I'm a runner and I use GPS trackers a lot. I tried to change the app from Endomondo to Runtastic but there was no effect. My tracking is full of waves and it is "rounded". I installed app called GPS Status. It shows sometimes my position with 10m accuarcy but the most of the time there is +-65m and even if the phone is not moving it shows speed occasionally. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Hello,
i would advise you to swap out the internal antenna it's weak and internal antenna isn't so expensive so go for it. Guide and every thing will be down below. If you don't have tools required to oppen up your device i will also post that down below.
Internal antenna:
iPhone 6s Wi-Fi Diversity Antenna
Tools:
Pro Tech Toolkit
or if this is too expensive you should buy this next tools:
you can find this tools at this link but just scroll down to tools:
iPhone 6s
EDIT:
Forgot to paste the guide link so here it goes:
iPhone 6s Plus 左上方的Wi-Fi天线更换
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.图片
产品
Pro Tech Toolkit
$79.95
Replace the Wi-Fi Diversity Antenna compatible with the A1633 and A1688 model iPhone 6s smartphone. Fix unreliable connectivity to Wi-Fi signal.图片
产品
这个答案有帮助吗?
得分 0
2条评论:
Ok, thank you very much. I will tell later if it work.
由完成的 分享
I see you are new to this site so if my answer is correct you chose my answer for solution. If not you can wait for someone else to answer. And if some how good point you can up vote it. Hope it works.
由完成的 分享
添加一条评论
Hello,
I've changed the diveristy antenna, but it didn't help. The GPS is the same inaccurate as it was. Should I check something more?
这个答案有帮助吗?
得分 0
添加一条评论
iPhone 6天线柔性电缆更换
这个答案有帮助吗?
得分 0
添加一条评论
GPS tracker and network
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michał Wijata 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 1,487
