跳转到主内容
加入维修社区 - 创建账户
苹果个人电脑产品线 iMac 系列的首款机型。 iMac G3 发布于1998年至2003年之间。
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
由完成的
添加一条评论
1个答案
已选择的解决方案
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
这个答案有帮助吗?
得分 3
8条评论:
That's modding, the MAC didn't have that built in.
由完成的
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
由完成的
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
由完成的
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
由完成的
显示更多的3条评论
添加一条评论
添加你的答案
Denny Tuckerman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 717
