跳转到主内容
加入维修社区 - 创建账户
Repair guides for cell phones manufactured by Panasonic.
How to remove Pause option from Panasonic cordless KX-TG6821
Hi all,
this phone worked great so far.
All of a sudden , When I tried to make a call and after dialing the first digit, the pause icon appears on the bottom right corner of the display. According to the manual (http://panasonic.ae/en/manuals/KX-TG6821...) :
Pause (for PBX/long distance service users) A pause is sometimes required when making calls using a PBX or long distance service. When storing a calling card access number and/or PIN in the phonebook, a pause is also needed (page 22). Example: If you need to dial the line access number “0” when making outside calls with a PBX
I assume that I have pressed a wrongful key combination. Nevertheless I haven't found a way to remove this and retrieve the previous working mode without this pause to appear.
Update (01/08/2018)
I need to remove the pause
Update (01/08/2018)
Advice on how to,do,thi#.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi @dk1301 ,
Are you using the phone's Phonebook feature to make the call?
A "pause' may have inadvertently been entered along with the number.
Is it always to the same number?
If so, have you checked if the number stored in the Phonebook has the pause programmed in it?
Alternatively if it is from the Phonebook and it is certain numbers only try deleting them from the Phonebook and re-entering them
完成的
Panasonic KX-THF975 tried pushing off button many times but still can’t get Pause off.
完成的
I can't turn off the pause button either
完成的
Had same problem. Removed batteries, then replaced them. Back to normal.
完成的
添加一条评论
1个答案
已选择的解决方案
@dk1301 the Off button on these phones may help you out. Try to pick up the phone and press the OFF button multiple times. Then try to dial a number, by pressing the TALK button, and then the number. See if that removes the pause.
这个答案有帮助吗?
得分 2
6条评论:
Unable to remove the PAUSE ON SCREEN DISPLAY ON WIRELESS HOME PHONE PANASONIC
完成的
Can’t get it off
完成的
@denali can't get what off? Can't turn it off?
完成的
Boy you accidentally touch a button and then you can’t find the answers online. My elderly mom needs her phone to work consistently but one slip and she’s without a phone. Ridiculous. Hitting the off button a bunch of times does nothing!!
完成的
@juliannedraher
What is the model number of the phone?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
dk1301 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 78
总计 11,527
