跳转到主内容
加入维修社区 - 创建账户
Xterra 于 2004 年在第 1290 届纽约国际车展上首次亮相。该车型在 2005 款车型上进行了重新设计,采用了与 Frontier 相同的 Nissan F-Alpha 平台,并于 2004 年 4 月进入展厅,作为 2005 款车型发售。
No Acceleratror pedal control
I got a code p2122, accelerator control sensor on my 2005 Nissan x trail. I have changed the pedal control sensor and the fuel control on the intake and checked the connectivity of all 6 wires from the pedal to the control body and all seems to be fine. I still have engine light on with code p2122 and no response to the pedal still. Where should i go searching now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
I now have this problem also. I have replaced the throttle body and the pedal sensor and still the gas pedal does not work. Have you finaly solved the problem and what was the repair if so? Thank you.
由完成的 分享
添加一条评论
1个答案
It is possible it could be a bad throttle body module. The code that you got basically means that the PCM is seeing low voltage (below .17) on the throttle position sensor circuit. Usually this is a pedal but it's possible to be the throttle position sensor or the actuator motor. Both of which are serviced in the throttle body. The throttle body is available on the aftermarket if you don't want to go factory.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lonny Nohnychuk 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 30
总计 2,803
