跳转到主内容
The HP Pavilion dv9000 series was introduced in 2006.
Why does it shut down when touching the touch pad?
My laptop works fine until i put my hands on the touchpad then, its shuts off and reboot itself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
i can't use my laptop anymore:-(
完成的
添加一条评论
1个答案
已选择的解决方案
Can you attach a USB mouse and disable the touchpad and see if it works as it should without the touchpad
1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
2. Double-click Mouse in Control Panel, and then select Disable .
3. Click Apply , OK .
Also try to remove your battery which is housed underneath it I believe and see if you have the same problems w/out the battery, just run it on AC.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dijae10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,842
