跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
What is the best way to adhere home button to new screen?
I have replaced the broken screen/digitizer on my ipad 4 mini, however I am trying to find the best way to attach the home button to the new screen. The home button is still affixed to the flexible gasket, and the flex gasket is still attached to the flat washer-type piece that adheres to the glass, so I just need to attach the washer piece to the glass. I need something thin enough to keep the button flush to the surface (not sunken in the hole of the new glass), yet strong enough to hold for the long term. I'm afraid if I use glue, it will stick the sides of the button to the glass. and not allow it to move at all.
I also need a solution for the worn out adhesive on the button bracket. Not sure if I should use the existing tape to hold it place and glue around it or scrape off the tape and start with something new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I like to use quality adhesive for the bracket. You have to clean off all the old adhesive to insure you get good grip. If the bracket holds firmly, even the residual adhesive on the gasket and washer will suffice. I use the pre-cut templates from BowlerTech. I specifically get the bulk kits that include the extra tape that was not trimmed so I can make a custom cutout for the mini 4 bracket. BowlerTech also offers the extra trimmings separately. Or you can use Tesa Tape sold here on iFixit but you have to buy a whole reel.
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 2
添加一条评论
You typically use a special double sided tape used to adhere to screens and other items. Here is an example.
https://www.amazon.com/Adhesive-Touchscr...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TonyM 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 37
总计 6,730
