跳转到主内容
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
Why is my TV blinking?
We have a Toshiba flat screen LCD that constantly blinks -- goes dark for a half second like the LEDs are turning on or off. Changing the picture mode can alter the rate of blinking but I cannot get it to stop altogether (although this has worked in the past). Any suggestions on how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
8条评论
So do you have to get a new tv
完成的
I've been having this issue about a month now. It comes and goes...so I'm a bit confused. Ant solutions? Or suggestions to self check before taking it to be repaired?
完成的
I’m not seeing a way to adjust the setting without the TV remote… Is that true?
完成的
I raised my back light to 100 and it started blinking faster as I went up. I lowered it to 60 and there’s no blinking
完成的
How can u adjust the back light I've tried won't let me
完成的
显示更多的3条评论
添加一条评论
2个答案
最有帮助的答案
@alf222 let us know the exact model of your TV. If it is the screen that is blinking it is possible that you have a bad power board/LED driver or a bad LED array. Post some good images of all of your boards with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
Update 01/19/2024
Just to clarify why decreasing the backlight will work (for a while). As one decreases the brightness, the voltages to the backlight strips will decrease. Less power = less heat. That will keep those strips illuminated for longer. This may or may not work for a while. For a permanent repair, the backlight strips that will require replacement.
这个答案有帮助吗?
得分 7
6条评论:
@alf222 Thank you, lowering the back light and then raising it to 80 (too chicken to go higher) worked, no more flashing on and off picture
完成的
I have a 2 1/2 year old Toshiba that blinks on and off. How do I reduce the numbers spoken about above.
完成的
I've got a 50 inch Toshiba telly in mind links as well he actually gets on your nerves after a bit and it's only 3 years old I don't know what to do about it either I'll try turning my back light down to 18 see if that works but if anybody else has got any suggestions what it might be won't mind knowing also just go out and buy a new telly and not a Toshiba one this time or all tell us the same thank you
完成的
I just fixed a 70 inch Vizio with this problem. It was a dead completely shorted diode on the power supply for the backlight driver. Since this problem can often be fixed by turning the brightness down it is almost certainly either the power supply or the LED strips inside the display panel. I would start with the power supply first though.
完成的
It appears that adjusting the back light worked like a charm! I did notice that changing the 'Picture Mode' from ie Movie, PC etc to Gaming helped reduce the blinking on my TV (yours might need to be adjusted to one that works for you).
完成的
显示更多的1条评论
添加一条评论
One of the chips is overheating. Use freeze spray to identify it, unsolder the heat sink, clean well, then use a good heat sink paste and resolder the heat sink back on. You can try turning the backlight down in picture settings as well. Menu-picture-Backlight. It is factory set at 100. Try turning it down to 50, then bump it up by 5 until the picture blinks. Bump it down 10 or 20 from there.
这个答案有帮助吗?
得分 5
6条评论:
Amazing. Everywhere else said I needed a repair. I lowered mine from 100 to 80 and it stopped blinking. Its a little dimmer and I will probably still need to get the repair at some time but this will work well for now.
完成的
I turned the backlight down it worked
I turned the backlight down then reset the picture it worked on mine.
完成的
I turned the backlight down on my 50inch toshiba and it worked
完成的
Mine is toshiba with roku. Decreasing brightness helps.
i have also fixed before by cleaning. Take the back off, vacuum inlet filters, use a soft brush on all exposed surfaces to remove dust while vacuuming.
完成的
I have a Toshiba. Flickering was driving me nuts. Lowered my backlight to 54, flashing stopped! Fingers crossed, l hope this is a permanent fix.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Mike Fuhr 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 147
总计 46,568
