跳转到主内容
加入维修社区 - 创建账户
What does this error message mean?
^Please see picture^
Whenever I turn on my IMac I either get this error message or the screen stays black and the yellow light blinks 3 times and pauses repetitiously. Please help!
UPDATE:
New Error message after removing one card of RAM
After I tried to remove the PRAM this error message occured.
UPDATE!
New Error message
This error message is more consistent and the computer now even boots up and makes the sound.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you do what the screen said to do one the last photo you posted and type mac boot?
完成的
添加一条评论
2个答案
已选择的解决方案
Try re-seating the ram or try taking out one of the ram sticks. If this helps then it needs new ram.
这个答案有帮助吗?
得分 2
1条评论:
I think that getting new RAM will fix this issue because I tried re-seating the RAM, and swapping their places and it gave me a different error code mentioning the RAM. I will update this when I get new RAM.
完成的
添加一条评论
最有帮助的答案
That is called a Kernel Panic. It can be caused by either software or hardware failure. First thing to try is booting from you original system installation disk, go to the second page of the install to the pull down menu. Select Disk Utilities and see if you can repair your disk. Let us know your results or any changes please.
UPDATE 1/2/18
While you have the back off, inspect the capacitors (cans) on the logic board and see if any have expanded tops or show signs of leakage and/or corrosion.
这个答案有帮助吗?
得分 3
3条评论:
I do not have the original installation disk. Is there another way without the disk? I think it's a RAM failure. Messing around with the RAM was giving me different error codes instead of a blank screen.
完成的
Try using just one stick of RAM. We're going to test both the RAM and the slots. Put the RAM in one slot and try. Then move it to the other slot and restart. Repeat with the other stick. Have you changed the RAM or configuration, i.e. tried an upgrade?
完成的
I have not changed the RAM and whenever I type mac re-boot it fails.
I'll update you on if just one stick of RAM works
完成的
添加一条评论
添加你的答案
Caleb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 295
