跳转到主内容
惠普 “Mini”系列的小型上网本维修手册。
52 个问题 查看全部
Cracked Display Replacement Procedure...Tips?
My son inadvertantly cracked his netbook screen/display and we intend to replace the broken screen with a new one that will arrive in the next day or two. Anyone have tips for the most expedient way of detaching the screen bezel and opening the keyboard for access to the plug-in and such? A step-by-step would be very much appreciated if anyone has done this with their own HP netbook. Thanks a million.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Dave, there are so many laptops, and netbooks etc. that it becomes tough to keep it all in mind. That is why I try to always get a service manual before I get going on things :-) Anyhow I do have the one for your HP110 and I made it available to you for download at http://www.keepandshare.com/doc/2617573/... Can't get any more step by step than the manual. So if you download it you will have all the information needed for your task. Good Luck and let us know how it went.
这个答案有帮助吗?
得分 3
添加一条评论
You order new replacement screen online by checking of desired model. Once your recive the replacement screen then you can follow the online tutorials to follow the instructions if you are confident about your technical skills. Otherwise take it to hardware shop and get if fixed from there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 877
