跳转到主内容
加入维修社区 - 创建账户
Xperia Z1 Compact 是索尼推出的高端拍照手机。它与 Xperia Z1 型号类似,但体积更小、价格更低。其主要特色是搭载了一枚 2070 万像素的传感器。发布时有白色、黑色、粉色和青柠色可选。 可通过型号(D5503)识别该设备。
Sound Muffled without Headset
People describe me as muffled, talking in a cave, or breaking up when I'm not on the headset. Sounds like there's a problem with my mic. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @nygal ,
Use a strong light and a magnifying glass to visually inspect the voice inlet hole, found on the bottom edge of the phone, to see if it is blocked with dust or lint.
If it appears to be blocked use a vacuum cleaner, using short sharp bursts, to try and clear the obstruction.
If you don't have a magnifying glass try the vacuum cleaner anyway and then make or receive a call to test if it has been fixed.
Do not use a probe to try and clear it as the phone's microphone is directly behind the hole and could be damaged if you do.
这个答案有帮助吗?
得分 3
1条评论:
Helpful but it didn't fix the problem, unfortunately.
由完成的 分享
添加一条评论
添加你的答案
Laurie Barrueta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 502
