跳转到主内容
加入维修社区 - 创建账户
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Boot problems after changing combo drive?
Hi
I have an A1181 Mac Book Duo 1.83 ghz with 1gb Ram. After I replaced the Combodrive when I turned it on the Apple logo appears and the starting sound, then keeps the starting sound appearing like an broken cd and it don´t boot any further. This problem didn´t appear always, sometimes it boot normaly and sometimes you couldn´t turned it on for days. So I open it up again did all the steps for changing the combo drive and after I finished when I turn it on, the screen goes white without the apple logo and the starting sound appears, then it will take 3-4 minutes till Apple logo appears and it boot normal. I can not tell if it starts now always like this because i just opened it yesterday but I wonder if the problem is that something is touching the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Go under the Apple in the upper left hand corner to system preferences -> system -> start up disk and select your hard drive
这个答案有帮助吗?
得分 2
3条评论:
Still takes a minute, but it works Thanks
完成的
You're welcome. Did it take a minute to start before the drive change?
完成的
It varies from 1 to 3 minutes actually it didn`t change at all it seems to be a correlation between the temperature of the macbook and the time it takes to start to boot.
完成的
添加一条评论
添加你的答案
Mario 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 665
